Got the shank today. Much to my dismay it would not slide into my receiver. I got it in by pounding it in. Figured the paint needed to wear off. Once in the pin holes would not line up!! I could get the pin in one side but not out the other. Not sure if the tight fit is causing the problem or if the hole is drilled at an angle. For now went to Walmart and got the Reese reducer. The hole on it is a 5/8 hole and not Oblonged so I will see if that works till I can get a shank that fits. Hopefully I haven't banged up the shank I got so much that I'm out $140
