rcarpe06's avatar
rcarpe06
Serious Trailer Sway at Times
I have a 2014 Wildwood 30FKBS. There are apparently two different styles and mine is the one with the king size bed in the rear past the axles. The trailer is 35 feet long and I tow with a 2012 3/4 ton Suburban. From the dealer, driving home empty was no problem at all, but then after adding our stuff inside, I had some serious trailer sway going on. I basically couldn't tow above 55 safely. I then checked our setup, and the tongue weight with my Sherline said it was only 800 pounds. So I changed things around. All the storage compartments are in the rear, so I put the tool bags and stuff in the back of the suburban; I put the spare tire in front of the trailer axles; I removed the plywood boards for leveling and bought lynx blocks and store in TV. There is basically nothing left in the rear storage compartments and now the thing tows safely between 60-65. But wait, then I make a trip to Florida and after stopping and using the facilities a few times, I had horrific sway and bow-suction effect from semi's. I couldn't get the thing above 50 safely. So I removed the clothes from the closet in back, and dumped the black tank(which is behind the axles) and then it pulls better again. Is this trailer just destined to fail from the beginning due to the design of it? Or do I need to basically move the mattress and such in front of the axles to balance the thing? I'm ready to take out the rear stairs to save weight in back. Or does this TT desperately need a ProPride Hitch? Any suggestions would be great, so I can get back home without putting a death grip on the steering wheel.
Edit: After I removed most things from the back, the tongue weight was 980 pounds. And the TT loaded weight is 9100 pounds.
