Thanks for all the responses. I have read all your suggestions and here are my findings/responses:
TV tire pressure is set to max at 80 psi.
TT tire pressure is set to max at 65 psi.
Using a Reese Dual Cam setup with Trunnion Bars 1200/12,000 lbs.
TT is at a slightly nose low level when towing.
Fresh water tank is centered between the two axels.
TV is stock from factory, no upgrades with swaybars, etc.
The only thing left to move up front would be all the clothes and hampers.
I did try adding 2/3 full water to galley grey tank, which boosted the TW to 1100 pounds, but still had issues with clothes in back. I can't express how sore and raw certain fingers felt after driving that distance and (holding on) while traffic/semis passed.
