Frozen001
May 14, 2014Explorer
So last night we set it up per the reese instructions. Here is what we noted:
1) The hitch head as setup by the dealer was 4" lower than what reese instructs.
2) The slop between the 2" receiver tube and the 2" shank makes setting these things up difficult
3) We did this in his driveway which may not be 100% level. This weekend we are going to bring it out to a flat parking lot to verify the setup. I was not present when he made a final adjustment of tilting the head forward 1 tooth. Prior to me leaving the setup resulted in the front of the truck being almost 1" lower that unloaded height, and the trailer nose high. By moving the 1 tooth, he said he ended up almot exactly at the unloaded height. That said, I am a bit consered on how the angle of the head ended up. Attached it a photo of the setup as it was with the truck frong 1" lower than it's unloaded height.
I drew some lines on it using MS paint to attempt to highlight the angles. At this point the head looks like the ball is straight up and down. My fear is that by moving the head tilt 1 tooth less the tilt is now toward the truck. When we look at it this weekend I will have more information. If this is the case, I honestly thing my prefered solution would be a longer chain.
Also anyone know how to tell if his OEM receiver is flexing? I am concerned about that as well.
Thanks
Lou
Thanks
Lou
Moderator edit to re-size picture to forum limit of 640px maximum width.
Looking for advice before your next adventure? Look no further.25,197 PostsLatest Activity: Apr 30, 2025
