Frozen001
May 14, 2014Explorer
Campin LI wrote:Frozen001 wrote:That angle makes no difference.
My concern with the head tilt is in relation the ball axis has with level ground.
OK then if that is the case he has a lot of room to reduce the tension on it. The head original head tilt that resulted in too much transfer was using the Reese directions to set the tilt. (set by the height of the bar ends from ground on page two of the directs).
One area we both noted is that the ball of the newer trunion heads sits about 3/4"-1" above the top of the trunion sockets. We both felt if that was level or at lease closer, some of the problems with the bottom mount couplers could be reduced. This would bring the bars closer to the frame.
Looking for advice before your next adventure? Look no further.25,197 PostsLatest Activity: Apr 30, 2025
