The_Kragle's avatar
The_Kragle
Setting up new Trailer
Hello All,
I am brand new to towing and currently have just purchased a new Jayco White hawk 25BHS Travel trailer which has a dry weight of 5360 lbs and a hitch weight of approx. 600 lbs and GVWR of 6500 lbs.
I plan on towing the trailer with my 2010 Dodge Ram SLT 1500 with 5.7 hemi and 3.92 gear towing package capable of around 10000 lbs towing.
I have read lots of people stating that because of the coil suspension in my truck that I might require air bags to be installed to assist and keep the truck level. I have been looking at the Total Load Control option.
Obviously I will be using a weight distribution hitch but I still have not decided which one to go with.
I am currently deciding between the Equal-I-zer 1000 lbs 4 point hitch or the Reese Dual Cam hitch 800 lbs. I have read that the Equal-I-zer 1000 lbs might be too stiff for my trailer and makes quite a bit of noise but is easier to set up vs the Reese.
My questions are two fold:
1. Which hitch do you think I will need for the best ride and
2. Do you think that I will require air bags to keep my ride level and assist with my suspension?
My dealer wants to install a Reese Pro Trunion 800 lb set up with no sway control for $349 plus tax but I'd rather spend a bit more for safety only if its needed.
I also don't want to spend money on the air bags if they are not needed. They are currently on sale, so I would rather buy them now if I will need them.
Thanks for your help,
Rather do it right the first time.
Pete
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 21, 2026
