navegator
Apr 01, 2015Explorer
I had the same problem with my VW, severe shaking after going over a small bump or changing lanes and hitting the white markers.
I replaced the worn out shock absorber's and the problem went away, also check the rest of the steering.
Raise both wheels of the ground and use a pry bar to move all the moving joints, there should not be any movement, slight yes big no, if there is a centering shock disconnect one end and check it also, when the tires are free rotate them and see that they are ok, a small bump one one can also cause the vibration.
p.s. if you replace the shocks, replace all four, do not replace only one.
navegator
navegator
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
