webslave
Dec 10, 2015Explorer
If I had to guess what their fix will be..."This vehicle is not intended to be towed recreationally and such use will not be supported by the manufacturer" will be added to the owner's manual. All automobiles are designed for independent use and as such, I don't believe that any of the regulatory agencies can mandate a fix for a use the vehicle wasn't expressly designed for. I am also sure that there is small print somewhere that says that the information and specs can be changed at any time.
I am not demeaning nor minimizing the issues you and the other 39 people are experiencing, but, 40 people having the issue is a small number compared to the number of units that aren't experiencing the problem. There are currently now six of us snowbirding in this park...zero issues. Comparing the 40 having the issue for a use the vehicle wasn't expressly designed for to the 100,000 or more Cherokee units on the road that are perfectly stable for the purpose the vehicle was designed for means that their is no impetus for Fiat/Chrysler to do anything at all. As many manufacturers have already demonstrated, recreational towing is not a large enough market segment to be concerned with. I suspect the NHTSA won't have any control over it either since, again, the Cherokee is safe for the intended use for which it was designed.
I wish you, the 40 or so, all the luck in the world, but, the money just isn't justifiable, from a corporate standpoint, to bring many, if any, engineering assets to bear for an unintended use of the vehicle.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
