OpenRangePullen
Sep 02, 2013Explorer
Yes see If you can flush out the grey tank and keep the tank valve close When you leave it open, tho its a grey tank you would be surprised to see what (sediments/solids)still build up in the grey tank, bacteria is the (once again) most common source for foul oders. If you cant flush it threw a tank flush system fill the grey tank with about 3/4 water. While filling up the grey tank with water from the sink (warm water is the best) add 1/2 a cup of dish soap. After that let it sit for about 48hrs or if you want to speed up the processes drive it around to agitate the soapy water in the grey tank. Drive around maybe 20-30 miles. Then just empty the grey tank(s). FINISHED
Always add dish soap whether your using the tank flush system or filling the grey tank using you kitchen sink, always add a lot of dish soap. Dish soap breaks down bacteria, solids and sediments and smells too. HAVE A HAPPY DAY.
Looking for advice before your next adventure? Look no further.25,185 PostsLatest Activity: Mar 04, 2026
