- LwiddisNavigatorHe is a great Chinese name but I don’t encounter it much in the states.
- LwiddisNavigatorHe should check the roof vents.
- Dick_BExplorerAny chance the bathroom exhaust fan is on while dumping?
- redhookerExplorer IIIf equipped with washer hookups check that the drain is either capped or has water in the trap.
- Air admittance valve under one of the sinks is probably bad. You can get them for a few dollars at the big box stores. Google it to see what they look like.
- ScottGNomadMaybe it's the grey you smell. If the roof vents are installed wrong or blocked for any reason, dumping will pull water out of the traps and it can smell.
Grey can smell worse than black.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
