dcmac214's avatar
dcmac214
Shelf Life of Butane Lighters? ("Prepper" Question?)
(Assuming a butane lighter would be "best")
What brand & model lighter will retain virtually all its fuel and stay immediately-useable for years & years?
About 5-6 years ago, no longer able to get what I consider decent strike-anywhere kitchen matches, I got a couple of Bic butane lighters for the trailer. Doing my occasional winter check for signs of vermin I happened to look at the lighter on the stove (essentially new, maybe used 10-12 times) and saw that it was less than half full. So I dug out the other (still-in-package) lighter and it also had lost at least half its fuel.
What's the "Prepper" answer for a lighter or matches (not just a spark-maker)?
  • You can make a cheap waterproof matchbox with two empty shotgun shells.
    An empty 20 gauge shell full of matches will fit snugly inside a 12 gauge. I have a few of these in various places such as tackle box etc.
  • Diamond "Strike Anywhere" matches are readily available. I dip them in melted wax and they last for many years.
  • Chances are the flint will oxidize and turn to dust first.
    Same goes for those little "Survival" kits you scrape with a knife to get a spark. They eventually crumble to dust.
    Find some matches and store them well.
  • There are refillable grill/stove/cigarette lighters available and there are cans that hold a fair amount of butane for refilling them. You stick the nozzle on the can in a hole in the end of what you are refilling and press to refill.
    See
    HERE
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 18, 2026
