DallasSteve's avatar
Feb 11, 2021
Short Term Freezing Weather Tips?
I'm in the Rio Grande Valley (South Texas) and we are forecast for about 2 days of freezing temps Monday and Tuesday. The low right now is expected to be around 26 degrees. We are in a motor home with no skirting outside. I will keep the house temp at least 70 degrees through the night and I plan to keep the cabinets open and drip the faucets. Am I safe from frozen pipes or do I need to shut off the water and drain the pipes during the nights? Have you actually been camping through similar temps?
  • Most any RV is good to about 25F while in use with no special precautions.
  • Thanks again for the tips. One last question as the temps drop to freezing here in "Almost Mexico". I was going to leave the faucets dripping tonight, but I disconnected from the water main and drained my hose. My fresh water tank is full, but if I leave the faucets dripping it may use all the water overnight. Is it important to leave the faucets dripping?
  • down home wrote:
    Be sure your propane tanks are full.
    With what we've seen in Texas on the Weather Channel I would not drive my rig out to fill up with propane. If you have an extended stay valve on your rig, and have a safe way to get some propane, get some 20# tanks and use them. You could get 2 days per tank used sparingly.
    Actually my Winnebago Intent has 2 20 pound tanks that are removable. I took one over to fill it today. I'm helping them with 2 electric heaters. Tonight is a freeze and then we have a couple of days above freezing; then one more night of freezing temps followed by 70s. I'm ready for those 70s.
