- jplante4Explorer IIDidn't I already close this????
CLOSED - Grit_dogNavigator III^youre right. Since your drums aren’t balanced, no sense in balancing the wheels.....
Next thread, this ones on life support. - Turtle_n_PeepsExplorer
Grit dog wrote:
fj12ryder wrote:
wilber1 wrote:
And probably 2 or 3 times as much mass moving out there too.
How do you know it isn't balanced? Even if it isn't, why would you add to your problems by adding another unbalanced component that could exaggerate any imbalance? There is more mass and a lot longer arm (radius) to a wheel and tire than a drum. The outside surface of a 235/80R16 ST tire is traveling over 2.5 times faster than the outside surface of a 12" drum.
You'll have trouble explaining the physics of that to some....as evidenced by some of the posts in this thread.
Is it 10x or 2 or 3x's?
Since we are all guessing I say it's 1.10000003492 x's. - Grit_dogNavigator III
You'll have trouble explaining the physics of that to some....as evidenced by some of the posts in this thread. - wilber1Explorer
Drums are heavy but kinetic energy increases as the square of speed. A 2 oz imbalance at the surface of a 31 inch diameter wheel will have the same effect as a 12.5 oz imbalance on the surface of a 12 inch drum. When you balance a wheel and tire, you are balancing the whole assembly regardless of where you put the weight. - Turtle_n_PeepsExplorerBecause none of my trailer drums have balancing weights on them. NONE.
If your drums are balanced show a picture of them with the balancing weight welded on them. - fj12ryderExplorer III
How do you know it isn't balanced? Even if it isn't, why would you add to your problems by adding another unbalanced component that could exaggerate any imbalance? There is more mass and a lot longer arm (radius) to a wheel and tire than a drum. The outside surface of a 235/80R16 ST tire is traveling over 2.5 times faster than the outside surface of a 12" drum. - wilber1Explorer
Turtle n Peeps wrote:
wilber1 wrote:
LarryJM wrote:
wilber1 wrote:
If your TV will shake and vibrate from an unbalanced wheel, why would anyone think a trailer won't? Yes, back in the olden days when most cars had all drum brakes and solid rear axles, it was necessary to balance the wheels.
The tires on a TV especially the front are worlds different than a trailer. Just from the nature of the design with all the ball joints, bearings necessary for steering along with the entire steering mechanism which you actually hold onto via the steering wheel amplifies any NVH issues from out of balanced tire/wheel assemblies over a trailer that is a fixed rotating assembly with only a pair of bearings on the spindle.
It amazes me that anyone would even attempt to compare these two worlds apart situations .... they're not even in the apple and oranges category, but more in the grapes and watermellon realm.
Larry
It may not be as critical as in a steering system but do you not balance the rear wheels on your vehicles? A rotating mass that is out of balance will shake. It doesn't matter what it is. Just because you can't feel it in your TV doesn't mean it isn't there.
Why balance the tires/wheels if the rest of the assembly is not balanced?
How do you know it isn't balanced? Even if it isn't, why would you add to your problems by adding another unbalanced component that could exaggerate any imbalance? There is more mass and a lot longer arm (radius) to a wheel and tire than a drum. The outside surface of a 235/80R16 ST tire is traveling over 2.5 times faster than the outside surface of a 12" drum. - LynnmorExplorer II
Grit dog wrote:
^What on earth are you talking about? The rest of the "assembly." Like brake rotors?
Some are, some aren't. I've seen drums back in the old days that had balance weights on them and drilled rotors, but it's all about inertia. A brake rotor has only a very small fraction of the amount of inertia that a tire/wheel assembly has. I.E. A brake rotor could be 10x (for example) as out of balance as a tire before it has the same effect.
A trailer brake drum is only a couple of inches smaller than the typical location of wheel weights. Your 10x is nonsense. I have added more than 5 oz. of weight to the wheel to counter the effect of an unbalanced brake drum. Unless and until you check the balance of your brake drums, any discussion is just noise. You might get lucky and find that your drums are only out by an ounce or two. I balance the entire rotating assembly which includes the tire, wheel and hub/drum. - 2112Explorer III'll have to develop a Xmas tree shake indicator. I like the idea of using a baby monitor as a rear view camera.
Looking for advice before your next adventure? Look no further.25,190 PostsLatest Activity: Mar 31, 2026
