fj12ryder
Nov 02, 2017Explorer III
mike-s wrote:Actually this is what gave me that idea:fj12ryder wrote:What did I say to give you that idea? Brake rotors tend to be much more in balance than trailer drums, which have a large part of their mass farther from the axle. I suspect vehicle drums are also better than trailer drums - unless you buy the cheapest you can find, like trailers have.
So you don't balance the wheels/tires on your car either? Many shops balance tires off the vehicle, so what's the difference. I do agree that balancing on the vehicle is best, but sometimes that simply isn't done.
"Unless the brake hubs are balanced separately, doing just the tires/wheels can make things better or worse. You can also make things better or worse simply based on how the hub/wheel are clocked."
After all not all vehicles are equipped with disc brakes front and rear. I didn't see any exceptions mentioned, as you did in this post.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 04, 2026
