Turtle_n_Peeps
Nov 11, 2017Explorer
wilber1 wrote:LarryJM wrote:wilber1 wrote:
If your TV will shake and vibrate from an unbalanced wheel, why would anyone think a trailer won't? Yes, back in the olden days when most cars had all drum brakes and solid rear axles, it was necessary to balance the wheels.
The tires on a TV especially the front are worlds different than a trailer. Just from the nature of the design with all the ball joints, bearings necessary for steering along with the entire steering mechanism which you actually hold onto via the steering wheel amplifies any NVH issues from out of balanced tire/wheel assemblies over a trailer that is a fixed rotating assembly with only a pair of bearings on the spindle.
It amazes me that anyone would even attempt to compare these two worlds apart situations .... they're not even in the apple and oranges category, but more in the grapes and watermellon realm.
Larry
It may not be as critical as in a steering system but do you not balance the rear wheels on your vehicles? A rotating mass that is out of balance will shake. It doesn't matter what it is. Just because you can't feel it in your TV doesn't mean it isn't there.
Why balance the tires/wheels if the rest of the assembly is not balanced?
