- Horizon170ExplorerI didn'r see any post about sand, I use beads.
MarvinDyna - LynnmorExplorer II
Horizon170 wrote:
Tire balancing now days is Cave Man style. I use Balancing Beads, do it once and never worry until I install replacement tires.
Marvin
Personally, I would never pour sand in a tire and have it try to somehow bring things into balance every time you start moving. How much do you add with a tire that is 6 ounces out and a brake drum that is also out by the same amount? It would need somewhere between zero and twenty ounces to work, depending on how the the parts are indexed.
In my example, the 6 ounces are measured at the wheel where weights are normally attached. All of the sand cannot be at the same location, so that is why I used the twenty ounce figure. So quote a figure, how much of that over-priced sand is needed? - fj12ryderExplorer IIIBalancing beads are okay for some applications, most notably lower speed applications. I won't use them, but some people think they work okay. No way would I use them for motorcycle tires.
- Horizon170ExplorerTire balancing now days is Cave Man style. I use Balancing Beads, do it once and never worry until I install replacement tires.
Marvin - fj12ryderExplorer IIIThanks, I work on my step-son's Street Glide so I don't really hate Harleys. :)
I have the simple Marc Parnes balancer and it works very well. And it has the adapters for my Interceptor so that works. But some of that stuff would be nice to have. - MFLNomad II
fj12ryder wrote:
2112 wrote:
I've known guys that didn't get their bike tires balanced, and they're always surprised at how much more smoothly the bike rides when the tires are balanced. I've had a few tires not need anything, but most need some amount of weight to balance. Harley's usually don't get them balanced because A) the weights vibrate loose and fall off, or B) the bikes don't go fast enough to need balanced tires anyway.TooManyTents wrote:
Because every trailer I have bought did not have the tires balanced. The only set of TT tires I have bought were in 2008 from a truck/trailer tire dealer. He insisted I was wasting my money balancing my trailer tires so I didn't. I have never noticed any imbalance issues on any tire I have owned, a total of 20 tires over the years.
The question I would ask myself is "Why would I NOT balance the tires?" What is there to be gained by not balancing?
My motorcycles are the same way but there is a dot to line up with the stem. But after some crown wear on the front tire they become unbalanced, I can feel it. The bike shop tells me balancing them at that point causes the front tire to wear out prematurely. I had one balanced and sure enough I was back buying a new tire after about 500 miles.
Discount Tires has the best price around for the GY Endurance so I'll have them install the tires. They charge $6 each for mounting and balance so balanced they get.
Thanks for all the feedback. It's always entertaining.
Hey Howard, some pretty fancy/expensive bike wheel balance equipment available now days, for the bikes that do go fast.
Thanks for the Harley chuckle!
Jerry - fj12ryderExplorer III
Thanks for all the feedback. It's always entertaining. - SidecarFlipExplorer IIIMy bike tires always get balanced but then my bike will run 150+ if I'm insane enough to do it... I'm not.
- JarlaxleExplorer II
Might want to try beads in the bike tires. - JarlaxleExplorer II
fj12ryder wrote:
mike-s wrote:
Actually this is what gave me that idea:fj12ryder wrote:
What did I say to give you that idea? Brake rotors tend to be much more in balance than trailer drums, which have a large part of their mass farther from the axle. I suspect vehicle drums are also better than trailer drums - unless you buy the cheapest you can find, like trailers have.
So you don't balance the wheels/tires on your car either? Many shops balance tires off the vehicle, so what's the difference. I do agree that balancing on the vehicle is best, but sometimes that simply isn't done.
"Unless the brake hubs are balanced separately, doing just the tires/wheels can make things better or worse. You can also make things better or worse simply based on how the hub/wheel are clocked."
After all not all vehicles are equipped with disc brakes front and rear. I didn't see any exceptions mentioned, as you did in this post.
Cars and trucks have their drums balanced...trailers do not.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
