DallasSteve wrote:
I'm buying a bumper pull trailer and the dealer is offering to install a weight distribution hitch for $1,000. They said it is an Equal-i-zer, I don't remember which model. It's my first trailer so it may be nice to have it set up, but I'm pretty sure I could watch a YouTube video and do it myself. I installed a base plate on a Jeep. I checked Amazon and I see Equal-i-zer hitches for around $700. GVWR on the trailer is about 9,000 pounds. I'm planning to tow it with an F 250 though I might get an F150 if people think that's plenty. The difference in price isn't a big deal. Would you pull it first and then decide if it feels like it needs the WDH?
Hi,
I will mention a few things not yet discussed.
First off, the WD hitch.
Make sure the WD hitch the dealer is calling an Equalizer is made by Progress Manufacturing which makes the 4-point brand "Equal-I-zer" WD hitch. A classic camper buying mistake for first-time trailer buyers is, the dealer-supplied an equalizer hitch, as they called it, which can be almost any other brand WD hitch. Generally, the cheapest one they can throw in is with a friction anti-sway bar. This is a very different WD hitch than the branded Equal-I-zer WD hitch.
Another dealer-supplied classic mistake is on the sizing of the WD hitch. If you have never been through this before, you expect them to give you the correct size for "your" camper. It only sometimes works that way. The WD hitch "needs" to be sized for the "loaded" tongue weight, not the dry (empty) tongue weight. If they give you a standard, cheaper WD hitch rated at 1,000# tongue weight, and after you load the camper, you find out you have a 1,200# tongue weight, you have the wrong WD hitch.
The floor plan also drives the loaded tongue weight. Some floor plans load heavily towards the front, others less. This comes from the experience of knowing how to help predict the right size WD hitch needs to be. Too light is no good, and way too big is no good. Since you have a 9,000# GVWR camper in mind, 15% TW is 1,350#, 12% TW is 1,080#. And since you are looking at the Equal-I-zer brand hitch, that brand needs to have the whole hitch head and WD bars changed to jump sizes. So ideally, spend some time sorting out which WD hitch would fit your fully loaded floor plan. Odds are high, sooner or later, you will load it fully. Many of us do... If you tell us the make, model, and year, of the camper, we can help suggest the right size WD hitch.
Once you have sorted out the expected loaded TW, next comes the truck receiver and payload. The truck receiver needs to be rated at or above the WD hitch rating when in WD mode. The F150 might be WD mode limited below your needs.
Now comes the truck and payload; you are talking about an F250 or an F150. Pulling the camper is one thing; carrying the load of the camper TW, truck bed weight, and all passengers is a big difference between an F250 and an F150. What are your expectations for bed weight and people's weight? Are you going to have a truck cap? While the right-sized F150 might be able to pull the camper, can it handle all the added weight?
Where are you going to tow at? Long trips, short trips, higher elevation? Is the truck only needed for towing mainly, or is the truck your daily driver, and towing is a small amount of distance and time?
For my camping situation, given a 9,000# camper, I would go with the F250. But that is my case. I started out a long time ago with a truck that could pull the camper OK but could not hold up the weight once everything was loaded to go camping. And the larger truck makes for a more enjoyable towing experience. You do not have to get a diesel, the right-sized gasser truck will do you well.
Hope this helps.
John
