LarryJM
Jun 25, 2018Explorer II
delwhjr wrote:
Direct quote from Dometic about being level:
"Thank you for contacting Dometic. The refrigerator should not be more than 3 degrees unlevel left to right, or 6 degrees unlevel front to back. We do not recommend having the unit unlevel for more than 1-2 hours as this can increase the chances of a blockage. However, we do recommend if you can, have the unit level at all times."
IMO that statement by Dometic is fairly useless since it bases it's recommendation on "BLOCKAGE" not some crystalization which can accumulate a little at a time and eventually create a "BLOCKAGE". I have also read that damage from being even somewhat off level can drive the ammonia mixture to exceed safe temp after about 15 to 20 min starting the permanent damage to start.
Larry
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
