- BB_TXNomadMine stays on full time when traveling. And that includes up and down mountain passes. And every other up and down on the highway, rest area, roadside pull off, etc.
- bukhrnExplorer IIIDefine, Not Level, a little, or a lot, I've camped in many CG's without being totally level, with no problems with the fridge.
If a Lot unlevel, go ahead and turn it off , it'll stay cold for as long as you stated. - jwandvassieExplorerNo
- pianotunaNomad IIII use the Arp controller but would turn off the fridge.
- MrWizardModeratori do when i make my 'mail' and 'grocery' runs
i shut off the fridge, 10 minutes or 40, fridge off
saves wear and damage, like you said, it stays cold
this rv has an LP fridge, previous RV had a residential fridge
but surprisingly this fridge is installed correctly and works very well
Want to keep it that way - DutchmenSportExplorerI have on several occasions, slipped a board under the tires of the trailer to keep it level when hitched to the truck and gone inside to shop or go to a restaurant while traveling. Just like at your camp site, find the spot where you'll stop. Lay your board (or Lynx Lego block) beside your tires, go backward just far enough to get the blocks or wood in front of the tires, and then pull forward onto the block. It's so simple to do, takes only a moment, and can keep the ice cream frozen like ice cream should be and not turn into ice milk if I'm delayed longer than expected. I do this all the time when traveling in uneven parking lots. No one has every said a word to me about it being wrong either.
- MitchF150Explorer IIII would.. Not sure if it makes any difference at all, but it's not that big of a deal to just push a button when you get there and again when you leave..
Good luck!
Mitch
Looking for advice before your next adventure? Look no further.25,149 PostsLatest Activity: Jul 17, 2025
