Y-Guy
Dec 17, 2016Moderator
If it's anything like our 2005 Raptor I would start by pulling the skylight and seeing what structure is above the shower. I think you're right if you pull the cross-brace you need something to keep everything in place. Another thought would be to cut the cross-brace, and replace with something during travel that would lock in place and hold the corners. This might be something that you do along with extended the vertical corners up to the ceiling and hopefully to the aluminum frame.
Looking for advice before your next adventure? Look no further.25,202 PostsLatest Activity: Jul 21, 2026
