downtheroad wrote:
My opinion: 35 footer, I'd be looking at a Reese Dual Cam Strait-Line set up or an Equal-i-zer. Hensley if you want to spend the $$$.
Yep.
Another friction sway bar is like $50. Try it.
But you probably should focus on WDH adjustment. Not enough or too much can cause handling issues. You are in the right forum.
Read this. Get the front axle weight/height the same with WDH as no trailer at all, and TT level to slightly nose down. A trip to a CAT scale may also help you understand where your current setup stands with respect to all your TV ratings.
