CincyGus's avatar
CincyGus
Explorer II
Aug 02, 2013
Sink Condensation
Anyone ever have sink condensation from having the /c set too cold?
Last week while camping, I noticed the shelf under the kitchen sink had a strong dampness, just short of what I would call being really wet. Upon closer inspection, noticed that the bottom of both of the split 60%/40% plastic sinks were wet with droplettes of water.
I wiped them dry, dried out the cabinet shelf and opened the doors of the cabinets and the problem went away. I ran water in the sinks, checked the water line fittings and all the plumbing connections and none showed any sign of water.
I was running the ac on high for the entire week and it was set about 67 and the outside temps were in the mid 80's.
Thoughts?
Do you think a coating of spray foam (to insulate them better) on the bottom of the sinks would solve this? I'm thinking because of the cooler temps hitting the tops of the sinks and the moist warmer air in the cabinet, it' causing condensation at the meeting of the two temps which is the bottoms of the sinks.
  • I would agree with others that in a humid climate with 2 AC units running set low you are over cooling and not dehumidifying the space. I'd have a humidistat to see what level you have. If is indeed humid inside and out you do should use a dehumidifier. If it is only damp inside and very dry outside open a window or vent to remove indoor humidity. Condensation on a sink seems minor but as suggested it can be everywhere and cause mold in fabric, carpet, the mattress inside cabinets, in the closet, simply everywhere.
  • I thought about this some more, and I have a thought and a suggestion.
    For anyone with two air conditioners: it would be advisable to only use one unit whenever you can. Why? Because too much capacity means cooling down the 'dwelling' too fast, which means not enough dehumidification is taking place. The result is a cold, clammy environment that leads to people pushing down the thermostat, but that only briefly fixes the problem, if it fixes it all all. So then, push the thermostat down some more . . . and soon, you're living in sub-70 degree surroundings and you're STILL not comfortable.
    Too high humidity is potentially a very damaging situation, to you as well as your dwelling. Get a humidity gage. They are cheap. Walmart probably has one for less than $10. If the humidity is regularly above 50% then this would be a good place to address your attention. If it's above 60% regularly, you've got a problem, you are inviting mold. Once mold gets started, then you must get humidity down and keep it down, as that is the only effective method of controlling mold. Better to not let it get started.
    Most people are very comfortable at 74 to 76 degrees if the humidity is 50% or less. Most people can't get comfortable at any temperature if the humidity is above 70%, and they usually have respiratory issues . . . for some odd reason.
  • I'd agree with slarsen. At 67 the differential in temp is going to cause a problem with Ny moisture and limited ventilation.
  • I would look at the possibility that moisture under the sink is the problem not the a/c. Ventilate as you did till you find the source.
  • First, I think you are making your trailer too cold. You're probably below the dew point and have moisture in more places than you think. If condensation happens in the walls, it'll start to stink. Once mold gets started, it's hard to stop. Couldn't you get by with, say, 72 degrees? Personally, I like 75-76.
    If you MUST make it so cold, you would be wise to add dehumidification. You can get a cheap humidity gage at Walmart, Target or any lumber yard, and know a lot more about what you are dealing with.
  • Our SS sinks have a neoprene type rubber that is glued to the bottom, that I am sure are there for the reasons mentioned above.
    Jerry
  • Most higher end SS sinks have undercoating sprayed underneath to deaden sound, reduce condensation and retain heat. I would remove the sink mask off the mounting area and drain threads and apply a couple coats to the plastic sink. Spray foam could be applied the same way but I've never had any luck without getting it all over everything as it expands.
  • I think your theory is pretty sound. As cheap as a can of spray foam is, it would be worth a try.
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 25, 2026
