PursuitAngler's avatar
Feb 12, 2021
Slide outs in cold weather
Headed up to Sierra this weekend. It's supposed to be in the low upper 20' to low 30's at night. It's supposed to rain only one day.
My question is, is it ok to use slide outs when it's near freezing Temps or should I leave them in?
  • If you have toppers I would leave them in as twice I have had a great deal of trouble getting slices in with ice and snow on them. At 20 I would leave mine in as the RV will heat much better
  • rhagfo's avatar
    rhagfo
    Explorer III
    tomman58 wrote:
    Slides are not insulated well so thinking you will be using the furnace they should dry out and any snow melted off of them. Their motors, screw drives are all under the unit out of the weather. We never have cared about cold other then we don't want to camp in it but it is a factor in late fall going across the USA.
    Typically it is only the floor and roof of a slide that is poorly insulated, the roof is about an 1-1/2” thick, but otherwise no worse than the rest of the trailer.
  • Slides are not insulated well so thinking you will be using the furnace they should dry out and any snow melted off of them. Their motors, screw drives are all under the unit out of the weather. We never have cared about cold other then we don't want to camp in it but it is a factor in late fall going across the USA.
  • It is okay, but if it rains, turns to ice, could be an issue to close. If you plan to leave in morning, before temp warms up, I'd put slides in before freezing temps.
    Slides may operate slower, due to cold, but if no snow, or ice, should not be a problem.
    Jerry
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 13, 2026
