rhagfo
Oct 06, 2014Explorer III
GENECOP wrote:
If you don't know how to remove those items, (Step One), then you probably should not try to make the repairs yourself...Additionally every RV has different conditions, generally standard, but still different...
Is the trailer in question tin sided of fiberglass??
If tin then it becomes more difficult to remove cabinets! With tin siding they are attached from the outside before the siding goes on.
Fiberglass are usually installed from the inside, but many screws are very difficult to get to.
Good luck
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 02, 2026
