Gjac
Oct 06, 2014Explorer III
I would pull back the covering to look at the damage if you can't poke a screwdriver through the soft spot, I would take an epoxy resin mixed with acetone to thin the mixture to almost a water viscosity, then pour it on the area that is soft and let it fully absorb. The acetone will flash of quickly and stiffen the soft area. If the damage is more severe you may have to replace that section of rotted floor. As others have implied the soft spot might be just the floor covering left with the wood underneath rotted away. Can you get to the corner to pull the floor covering back to look at it?
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 02, 2026
