keymastr
Oct 09, 2014Explorer
Treated wood is a poison that should never be used in an area that does not have a very good vapor barrier between the wood and living space. If it were me I would simply apply an interior varnish to the wood before assembly and then coat any cut ends to prevent water from getting to the wood should you ever have another leak. It will not leach poison into your sealed camper and will protect your wood at the same time.
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 02, 2026
