phenrichs's avatar
phenrichs
Small Generator question
I sleep with a CPAP. When we go out we always have electric hook ups. However I am planning to take a motorcycle trip with some friends. Two of us have CPAPs for sleeping. I am trying to figure out a small power source to run our units over night. I am hoping to come up with something small enough to to transport on the motorcycle that will also be fairly quiet.
I thought since many here have generators and have already done their homework there may be some good advice here.
Thanks.
  • You'll need to determine how much power the two Cpap machines draw and then match the generator with the correct sized output in order to get the smallest possible. I had a Honda 1000 watt generator back in the 80s, it was very quiet. About the same noise as a portable fan on medium spped.
    Depending again on the draw of your Cpap machines you may be able to plug an inverter into a power outlet from your motorcycle battery or add a second battery for more power. Each of you could run your Cpap from your own motorcycle.
    There are alternatives to the Cpap. Here's one Dr's website
    http://drgreenburg.com/sleep-apnea/cpap-alternatives
    I've also seen exercises that you can do to eliminate the need for Cpap by strengthening your throat muscles.
    http://www.sleep-apnea-guide.com/sleep-apnea-exercises.html
