JiminDenver
Dec 25, 2013Explorer II
wmoses
There may not be post under the name you listed but possible the same generator under a different name is here. The factory will produce them in any color and name plate as you ask and then produce a set in a different color for the next guy. They may even sit next to each other on the shelf with one costing more than the other but they are still the same generator. Once they are sold, you may never see that name plate again.
Honda, Yamaha and recently Champion are being recommended because the people here have found them reliable. Honda and Yamaha have huge brand names to help but Champion doesn't. I doubt anyone will argue that their 3500/4000 isn't pretty much bullet proof and now their inverters are gaining the same respect even though they are considerable less expensive.
Should you get the generator you are looking at, do us the favor of letting us know how well it does for you and if it does fail, how well is the customer service. That's how generators gain a reputation here, by actual use by real people.
Good luck in your research.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
