loggenrock wrote:
Save your money - "snake bite kits" are NOT recommended. Here is a link to a good article with accurate information, plus a couple linked references. ST
http://www.wildbackpacker.com/wilderness-survival/articles/treating-a-snake-bite/
The Six Don’ts
Don’t let the allow the victim to engage in strenuous physical activity. If necessary, carry the person to safety. Otherwise, have them hike out slowly without their pack so they are not over-exerted.
Don’t apply a tourniquet. Restricting superficial blood flow does keep the venom from spreading, which you want to avoid. Concentrated venom will rapidly destroy cells. Allowing it to spread will dilute the toxin and reduce tissue damage.
Don’t apply a cold pack. Cold reduces healthy circulation to the infected area. Also, some experts believe snake venom increases vulnerability to frostbite.
Don’t apply a suction device. Removing the venom by suction was once standard procedure, but is no longer considered safe treatment. These devices generally to not remove a substantial amount of toxin and can damage sensitive tissue.
Don’t let the snake bite victim eat or drink anything, including medication and alcohol, unless okayed by medical staff.
Don’t cut across the bite marks and attempt oral suction. Because snake fangs are curved, the pocket of venom will not be where expected and will probably have already spread. Plus, many snake bites are considered “dry,” where there was no toxin released into the victim. This may also increase the risk of infection in the area by having an open wound.
