I set the heat to 55 back home. But then I also winterize the house in case the furnace fails. I have the water dept. turn water off at meter. I turn the water main off inside house and relieve the pressure on water lines. Leave all faucets open, including outside faucets. Turn off gas water heater and drain it. Fill all traps with -35 windshield fluid.
Leave kit & bath cab doors open. Move all water based liquids to bath tubs and rubber maid tubs. That includes the garage.
About the only thing I don't take the time to do is blow out the water lines. This way I can sleep soundly knowing even if heat fails, there will be minimum to no damage back home.
