Terryallan's avatar
Terryallan
Explorer II
Sep 04, 2018
So. Backed into a tree.
After backing out of the road thru the obstical course in my front yard. I have to back out of the road at an angle, between 2 trees while dodging the 2 trees behind them. so while attempting to do that for the millionth time. I finally after 35 years. Didn't dodge one of the back trees. Yep I hit it. Broke a limb off, and every thing.
However. The only damage to the TT I can find is some green sap on the back, and a bent molding tray on the corner. Of course the molding caulking needs replacing. The fiber glass is not broken. So I'm thinkin / hoping that all I need to do it recaulk. I'm going to remove the molding, and see if any of the tray screws are loose or if ant thing under the tray is pushed in. Would be great if it was just that far off the corner, and not tight up against the back or side.
BTW. If I knew how to post pictures I would. Can't ever get them to load.
Looking for advice before your next adventure? Look no further.25,180 PostsLatest Activity: Jan 23, 2026
