My way of thinking is the solar panels for we small system RV'ers are just battery chargers...  Who of us can afford the very large solar panels and where are we going to install them when camping off grid.
Connecting the Power Inverters directly to the Solar panels has all kinds of problems.   You will need a very large solar panel setup producing very large DC current to run the high wattage Power Inverters. The Power Inverters will only work when the panels are in high sun.
Unless you have these hugh solar panel setups the best way in my way of thinking is to have a battery bank large enough to develop the required DC Current for your planned High wattage Power Inverter and then just use the solar panels to keep the batteries charged up in the battery bank. Then when the sun goes down you still have the power stored up in the batteries to continue on...
This is the way I am going to build my solar panel setup...
Because of my roof space being small I will only be able to produce around 20AMPS DC current for 5-6 hours a day if in high sun times using two 100WATT panels on the front of my trailer roof and one larger perhaps a 250WATT solar panel across the back of my trailer roof.  I will still be required to have my 2KW generator around as primary battery charger and only revert to solar panels when I have high sun...   This is the only way in my case to be able to 'depend on' using my battery bank to run my Power Inverter when camping off-grid.
I probably have a bigger Power demand with my Radio OPS than most of the causal campers that can get by with just minimal DC lights and maybe running a HDTV setup.
It all depends on your style of camping off grid on how big a system you will need to have...
Back in the old days we got along just fine with a bag full of D-CELL batteries and a can of white gas for the camp stove and outside lights.
That's not the case anymore unfortunately haha...
My charging plan will be use my 2KW generator to connect to my camper trailer to run my on-board converter/charger for the first hour to get past the very high DC current demands by the charging batteries then when they start tapering back shut down the generator and allow the solar panels producing 20AMPS DC current to bring the batteries back to their 90% charge state before I loose high sun.  This is the only safe way for me to do this.   Some days of course will not have high sun available so I have to have my generator available to run for three hours to get my batteries back to their 90% charge state.
Using my generator for three hours a day has been my method since 2009 and just now wanting to add solar panels to cut back on the use of my generator...  My goal is to just produce 20AMPS DC current from my solar panels for 5-6 hours a day... Note a typical 120WATT Solar panel will produce 5-6AMPS DC current when in high sun...  The solar panel controller will produce the required DC Voltages just like your on-board converter/charger does...  Your battery bank won't know the difference if it is being charged by the on-board converter or by the solar panel controller.
I know others have different ideas about this but this will work fine for me...
Roy Ken
