time2roll
Nov 05, 2023Nomad
TenOC wrote:Generally this is correct depending on equipment. Having multiple charging sources is not an issue.
I assume that when connected to shore power, (or a portable generator) the shore power not the solar panels is the primary method charging the battery bank. I also assume that when towing down the road the tow truck alternator and the solar panels are each charging the battery back.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 21, 2026
