- dodge_guyExplorer III have the same model on the front of my trailer. it does a good job of keeping the battery "topped off". I used to have the battery be low after a month of sitting, one time it was dead. since I installed the solar battery maintainer, the battery has always had a full charge, I installed it about 3-4 years ago!
No you can`t dry camp with it! but it does what it is intended to do. - RAS43Explorer IIII tried a 2watt charger for my pickup which sits a lot in the winter. It didn't help much. Now I have a 5 watt charger and it keeps up with whatever draws on the batteries when shutdown for weeks. yes, I know-drive it occasionally. That is fine when circumstances allow.
- westendExplorerThe 2 watt module may just keep up with typical self-discharge of a single battery but I doubt it's an effective solution. I would be looking more towards 50w-60W to get the job done.
- BobboExplorer IIII used one similar to that with little luck. However, location is everything since I wasn't getting many hours of direct sunlight where I was having to park the RV. If I had parked in full sunlight, my results may have been different.
- Vet_ManExplorerReviews are good. I have a solar charger on the roof of my MH, that was a factory install. Does nothing for the house batteries, Friend shifted his over to his engine battery and said it worked. Less drain on chassis battery.
Looking for advice before your next adventure? Look no further.25,149 PostsLatest Activity: Jul 17, 2025
