- Gau_8ExplorerI just spoke with mobile outfitters today. The sleeve has been halted with technical problems but I got the impression that the topper is still available. Apparently the issue is interference with the seals. Specifically those applications where the bulb seal is on the wall of the RV and not the slideout. I spoke with two people and neither gave me a warm fuzzy about the product. Too bad as it is a good idea. I may make my own.
- jdogExplorerSolera is a branch of The Mobile Out-Fitters. I was called back by the company and was told that the Solera Slide-out Sleeve was on hold untill the company worked out some installation problems with a few brands of RVs. Nothing is wrong with the material or the entire product, just few problems with installation. It will be available soon again.
- Chris_BryantExplorer II
robatthelake wrote:
I am thinking that "Google" has some sort of Memory~Direction thing Chris!
Yes- it does. I often have to go to incognito mode to get good search results. Sometimes it's a good thing, but often it isn't. - doxiemom11Explorer IILooks like a good thing. Will think about adding this to our coach. Who sells them. We do not get anything up other than information. Do you have to go to one of the dealers to get them?
- mlts22Explorer IIThe Solera slide boot/sleeve is a cool idea, especially when used in combination with an awning. It goes a long way to protect against water intrusion, from what I've seen.
If/when you (the OP) has it installed, let us know how well it works, if you don't mind. - robatthelakeExplorerI am thinking that "Google" has some sort of Memory~Direction thing Chris!
I had been looking at Toyota Vehicle information a few Days earlier.
When I typed in Solera Slide Out Sleeve it went searching for Toyota accessories.
You ,no doubt ,use Google a fair amount on RV Related Products!
By the Way Thank You for all Your Helpful Maintenance Manuals and Links.
Rob - Chris_BryantExplorer IIYou can find a dealer list at http://www.themobileoutfitters.com/index.php/dealer-locator.
Interestingly enough, I Google "Solera slide out sleeve" and the first 2 pages are nothing but the Solera slide out sleeve. - robatthelakeExplorerUnfortunately You haven't given Us enough information. Please remember to include things like :
E.G. I would like to install a "___" on my " ( ___ Motor Home) !
OR I'm Looking at " ____ " on Website XXXzzYY can anyone suggest an installer!
I tried to Google Solera slide out sleeve and came up with references for a Toyota Wind Deflector!
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Dec 14, 2014
