jimmyfred's avatar
jimmyfred
Source of Macerator Pump for Trailer mounted Black Tank ?
.......I'm doing property monitoring on a small tract that will be developed into a RV storage facility ! The septic drain line is several inches higher than the 3 inch drain outlet on my 5'ver ! So , I'm trying to find a source for one of those macerator pumps used by gate guard companies , where they bury a small plastic tank in the ground with the macerator pump inside the tank(next to the RV)........and the dump from the trailer goes directly , INTO the buried plastic tank !
.......The level sensor(inside the small buried tank) will turn on the pump where it will pump contents of small , buried tank INTO say a 500 gallon septic tank , usually mounted on a trailer . Any info will be appreciated . , thanks , jf
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 13, 2026
