I myself tow at a top speed of 60mph as a target. It can go slightly over or under but not much under 55mph other then large climbs. I also live in a state that has a trailer towing speed limit for non commercial towing. My current LT tires on the camper can handle a lot more speed then this, but I have no need to tow any faster and never have. If something goes wrong towing a camper, it can go wrong really fast and 60 is my limit.
I myself did stop using ST trailer tires a while ago as 3 of the same set had internal detachment. They where not made in China, they where made in Mexico as that is where Denman made them before they went out of businesses here in the USA.
On those 3 tires, it was not weight, speed or age that took the tires out. I went to great ends to understand the root cause of the issue before I switched tire makeups to make sure I was not doing something wrong. This post documents this along with the complaint filed with the NHTSA.
ST Tire Failure Analysis (Long - Lots of Pics)I did run Maxxis tires before the Denmans and while they did not have tire internal failures they did have cracks forming in the treads like clockwork at 4.5 to 5 years time frame. I do however run Maxxis trailer tires on my 10,000# flat bed trailer but it does not get the same long haul distance the camper gets.
And yes, I now have a TPM system on the camper. I did not before but do now. And always check tire pressure before each trip and look over the tire at every stop. I found all 3 of my failures before they let go just by looking. It is amazing what you can find just by looking.
There is a lot of understanding to be learned on trailer tires, first is are they sized correct with the extra capacity needed for a tandem axle setup. This starts at the RV manufacturer. Then does the owner weigh the camper and know their wheel weights and are they where they are supposed to be with the extra capacity needed for a tandem axle setup? Are the aired up every trip correctly? Do they get covered during storage? Do you stay under the speed rating all the time? Do you replace them at the interval that aligns with that tire manufacture? Once you get all that sorted out, then there are road hazards that come into play.
Trailer tires on a camper that is towed a lot takes work and understanding. And even then there can be a failure. Do your best to educate yourself and keep on top of it is your best defense.
Safe towing to all
Thanks
John
