longislandcampe's avatar
Apr 27, 2013
Splicing Into Fridge 12V?
I was curious about installing an LED light strip on the side of my TT, directly underneath my awning. I have a 16' extension cable and was thinking about running the extension cable down the roof vent for the fridge and then come out behind the fridge.
To power the lights I wanted to splice into the 12V line for the fridge. What exactly is the 12V line for the fridge powering? It seems to be a thicket gauge wire then I thought it would be.
This method would give me a very clean install so I hope it's a good route to take.
  • I wouldn't do it, if you blow the fridge its gonna be expensive to replace or repair and it is very apparent you're not sure what you're doing so I would pass that up. Why do you need 12V lights on the awning anyway?
  • If you have a three way fridge it is probably the 12 volt feed to run it on 12 volts. And, yes it could be for the control board, but it doesn't require heavy wiring.
  • Mine powers the control board on the back of the fridge, the inside light and front panel indicator lights.
    I suspect it is a dedicated circuit and doesn't power anything else except the fridge.
