MrWizard
Jan 08, 2014Moderator
john&bet wrote:
The safety of the idea has not been address yet so let me be the first. You have the potential to overload the neutral of the adapter or the neutral of the recptical or the neutral anywhere up stream of that point. If both 30 amps are loaded to say 24 amps then there is 48 amps on the neutral which will be pushing it and the connections. JMHO.
And what is the difference
Between that and a 50 amp rig using the same amount (24) on each of it's legs
That 50amp is 50 amps on each leg , 100 amps total
Two 30 amp rigs can only use 30 amps on each leg
50 amp RV is wired as two 120v 50 amp legs neutral load is not zero, not 240v
There's always a neutral current equal
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 19, 2026
