Mountain_Mama's avatar
Jun 13, 2018
Stanley Fatmax 1000
Does anyone have one of these? Got it in Nov at Sam's Club. We’ve only used 3- 4 times and it has died... It won’t recharge. DH is wondering if there is a fuse inside somewhere that could be blown. Any ideas??
Fatmax
  • I received one as a gift and used and charged as directed. It lasted about 11 months until it started turning itself off when using. Still appears to charge correctly but will not stay on.
  • When was it last charged
    These devices should be charged once a month, every month even when not used
    The batteries self discharge
    does it light up and indicate plugged in when you try to charge it
    if so, then most likely the battery
    Battery gone bad is the most likely problem
    Open it up and replace the battery
    i don't belive there is charge only fuse
    but should be a power in fuse, inside for the 120v line
    maybe a 12v fuse in the 12v charge cable plug
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
