Picinisco's avatar
Picinisco
Steer tires
Does tread pattern on the steer tires influence sway. I suspect that it does. What tires would be recommended. I pull with a 2007 Chevy Tahoe.
    Yeah...tread patterns and tread depth can cause a trailer to sway ...usually until the tire is broke in. MT and AT with large lugs and voids can exhibit tread roll and cause the trailer to sway.
    Generally a good AS or a tire with a tread pattern with solid ribs something like the tread pattern on a class 8 tractor once its broke in can eliminate sway issues.
    What size/load range tire do you need. We have no idea what size you have on the vehicle.
  • New tires can also cause sway and handling problems when towing. I had a sway problem with my Ford pulling our TT the first time or two.
  • Does it sway when you aren't towing? My guess is move some weight forward in your trailer.
  • They will only effect handling if a belt is broken. Some tread patterns can create wander, but if your having handling problems look at suspension and tires them selves.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 02, 2025
