pira114
Mar 29, 2015Explorer II
If you put anything on the bumper, the trailer will actually explode.
Unless you have a 1 ton dually. Or a Propride hitch. Then you can load it up all you want.
Just messing with all of ya.
I had my Gen on the back of my 26ft Wilderness. Haven't noticed any difference since I removed it. Only reason I did was my new storage spot has an extreme driveway and I hit it pretty hard going in or out. Had to come off.
So if that's not an issue, I don't see an issue with a plastic box, BBQ, and assorted supplies. I'd be careful how heavy of a bumper you add maybe.
Personally, under 150lbs, I'd probably use an elevated cargo tray that uses the rear receiver.
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: Apr 08, 2026
