RobSpook's avatar
RobSpook
Strange tire problem - can't find info
Howdy y'all! We've been on the road since last February or so and have been pretty happy with the Towmax STR tires came on the camper. However, I recently noticed while installing my X-chocks that one of my tires has changed. Where the treads are usually flat across from the inside to the outside of the tire, one of the tires is now somewhat balloon shaped all the way around. This is NOT a tread ware problem, if you place a quarter in all the grooves, the tread ware is even... But the tire tread for this one tire appears round when viewed from the front or back. It has the effect of increasing the circumference about 1" around such that he X-chock is noticeably tighter on this side than the other.
I'm planning on taking it to a TowMax
Dealer today between Montgomery and Clarksville...
Which brings another question... Since the tires are a year old and have about 15,000 miles on them, should I replace only this one or both on the affected axle?
Thanks and safe travels!
Looking for advice before your next adventure? Look no further.25,197 PostsLatest Activity: May 23, 2026
