Crowe's avatar
Crowe
Stupid question about tires
So y'all can call me uneducated, stupid or whatever you like, but the 5th wheel we are looking at comes with nitrogen in the tires. Are there nitrogen pumps available? Can you mix it with air or just swap it over? Just seem weird to me.
  • gimmick
    unless you are racing and having issues, so I doubt you are.. it would be better to use a stapler and tack a note to your forehead to not make life so complicated than to put nitrogen in tires...
  • bob213 wrote:
    There are nitrogen pumps but not really affordable for home use. It's a gimmick. Just use that 78% nitrogen that comes out of your air compressor and you will be fine.
    +1. this question or one like it surfaces from time to time. bob is spot on. if the seller is using nitrogen as a selling point or to charge extra then i'd walk away.
  • There are nitrogen pumps but not really affordable for home use. It's a gimmick. Just use that 78% nitrogen that comes out of your air compressor and you will be fine.
  • Pure nitrogen is more stable in pressure vs temperature.
    Other wise it's 100% compatible with the standard 78% nitrogen mix that we all breathe.
    Bottom line it's not a bad thing, nor is it worth any $ or favorable consideration in your purchase decision.
    The cynical and skeptical side of me would just presume that the dealer bought a bag full of green caps and is spending $0.67 per RV to upsell with nitrogen in the tires....
  • You are breathing 78% nitrogen right now and, yes, it mixes with...air.
Looking for advice before your next adventure? Look no further.25,163 PostsLatest Activity: Mar 21, 2020
