- Grit_dogTrailblazerJeep JKs and JLs.
Lots of good 4 down options. - lryrob9301ExplorerThe easiest to tow, most reasonably priced SUV available is a Chevrolet Equinox. Look for a 2017 to 2010 model either 4cyl or 6cyl. I prefer the 6cyl models due to their hydraulic steering and better performance. 4down towable, no modifications needed just hookup, pull one fuse, put in neutral, turn key to off, DO NOT REMOVE THE KEY, and your ready to go. I have one and have towed it over 25,000 miles with no problems.
- Y-GuyModeratorA good first place to start looking is to check the Motorhome Magazine Dinghy Towing Guides is a great place to start, however it was last updated in 2020 so it’s dated and I’m unsure if they will be updating for 2021. It provides a great overview, but doesn’t get into many details. Keep in mind that some vehicles that could be towed one year might not be recommended the next year, either changes to electronics, transmission, engine or the bean counters can all influence the change.
The ultimate authority is the actual Owners Manual that came with the vehicle. In most cases you can do a Google Search with the year make and model to find one online. But you will want to verify with the actual owners manual of that vehicle to be sure since sometimes the online ones might differ from the actual. Generally speaking you want to look for the section on "Recreational Towing" in the owners manual.
There are users that find out that they can tow four down just fine, going against what the manufacture states. If you go this route you’re on your own if there are any damages, this is why many won’t risk violating the warranty by towing against the owners manual recommendation. - dodge_guyExplorer IIWe tow a 13 Ford Explorer. The Explorer and Edge are both 4 down towable not sure of the very recent ones. You also have the Jeep,Cherokee with Active Drive II and the Grand Cherokee with the 2 speed T-case.
- Ranger_SmithExplorerWe purchased a 2016 Lincoln MKX loaded for 17k. Just put in neutral and go.
- LwiddisNavigatorDon’t take anyone’s word that a specific vehicle is four down towable. Check the manufacturer’s materials.
- gboppExplorerGood advice. Maybe other members can advise the OP on what would meet their criteria.
- wanderingaimlesExplorerYou could start here. Dinghy guides
These guides help, but with any vehicle, ensure the exact one you are considering will allow it. Check via the Owners manual whenever possible.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
