centerline's avatar
centerline
suggestions for a better shower head????
im looking for suggestions for a shower head that will give a wider spray of water.
the one that i have now sprays about a 2inch pattern at 24inches from the shower head, and I would prefer to have one that has about a 5inch spray pattern....
due to heartlands use of the plastic fittings in the 1/2" pex line, which only have a 5/16 pathway thru them, more water flow and pressure is not an option without replacing all the joints with metal fittings, or upgrading to a larger size line thruout the freshwater plumbing system....
those of you who have a good spray pattern from your shower head, what brand or type are you using?.... thanks
  • The Oxygenics is probably the most popular: Oxygenics Shower Head
    They work on low flow making your limited hot water supply last longer. There are several different versions not just the above. We have had one for years.
Looking for advice before your next adventure? Look no further.25,151 PostsLatest Activity: Jul 25, 2025
