Dutch_12078
Apr 19, 2021Explorer III
If this is the ReadyStop system from NSA, the only way I can see it locking up the brakes without being pulled on from the front breakaway loop would be if the ReadyBrute/ReadyBrake applied the brakes and somehow the ReadyStop cable became jammed where it passes through the firewall. The ReadyStop cable is not in a casing like the ReadyBrake cable and there should be at least 3"-4" of slack in it between the brake peddle and the locking device. The slack should be wire tied where it can't be snagged by any moving parts of the vehicle.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
