rvjer
Jun 22, 2007Explorer
Well, IMO, an Aux brake system is a necessity. I understand that not all people think that is true and that is their privilege, but I KNOW my rig stops shorter and with less pedal effort with the brake system then without it. I have tested this under controlled situations to prove the point. Also having the ability to adjust the braking force from the dash of the M/H is a great bonus. Yes, any system can fail, but how many do you hear of in relation to how many are being used? My proportional system does need to be installed but it can be moved from one vehicle to another and I have done exactly that. The "brake in a box" systems are good in a panic situation and work fine if you don't mind installing and uninstalling it each time you use it, or if you change toads often it might make more sense.
Looking for advice before your next adventure? Look no further.25,202 PostsLatest Activity: Jul 21, 2026
