pulsar
Feb 28, 2006Explorer
Don & Nancy,
The Even Brake monitor has two warning messages about low toad battery conditions. The first is a statement similar to "low battery voltage in the towed vehicle." The second one is about shutting down. That message is similar to, "'Power Save' battery protection mode has been applied."
If you didn't get the second one, then the Even Brake system stayed fully functional. As previously stated, if it did go into 'Power Save' mode, you would retain emergency braking for panic stops and breakaway.
A question for you, does the monitor give you a readout of the toad's battery voltage?
Tom
Tom
Looking for advice before your next adventure? Look no further.25,202 PostsLatest Activity: Jul 21, 2026
