ReadytoRide
Aug 29, 2007Explorer
The system I use activates with the engine brake. It requires positive input from two sources to activate: 1) MH brake light on, and 2) toad is pressing inward on the towbar (ie moving faster than the MH). If either the MH brakes are released (service and/or engine) or the toad slows down enough to relieve the pressure on that switch, the toad brakes disengage. The amount of pressure to the brake pedal in the toad can be adjusted. The system also has it's own vacuum pump so it's not a "dead pedal."
Looking for advice before your next adventure? Look no further.25,202 PostsLatest Activity: Jul 21, 2026
